10 years ago.
Library for ENC28J60 on FRDM KL46Z
Hello, I want use your library for ENC28J60 on my FRDM KL46Z board but I'm getting error message while compiling program: Undefined symbol UIPEthernet (referred from UIPClient.cpp.KL46Z.o)
Is there any chance that this would work on my board? Thank you for your answer.
10 years ago.
Hi Radim,
It means that there is no UIPEthernet object defined (for the FRDM-KL46Z platform) in your program. Try to import the HTTPServer_Echo_ENC28J60 demo program into the online compiler. For me it worked smoothly after selecting the FRDM-KL46Z platform for the online compiler. The UIPEthernet object is defined in the following snippet:
#if defined(TARGET_LPC1768) UIPEthernetClass UIPEthernet(p11, p12, p13, p8); // mosi, miso, sck, cs #elif defined(TARGET_NUCLEO_F103RB) || defined(TARGET_NUCLEO_L152RE) || defined(TARGET_NUCLEO_F030R8) \ || defined(TARGET_NUCLEO_F401RE) || defined(TARGET_NUCLEO_F302R8) || defined(TARGET_NUCLEO_L053R8) \ || defined(TARGET_NUCLEO_F411RE) || defined(TARGET_NUCLEO_F334R8) || defined(TARGET_NUCLEO_F072RB) \ || defined(TARGET_NUCLEO_F091RC) || defined(TARGET_NUCLEO_F303RE) || defined(TARGET_NUCLEO_F070RB) \ || defined(TARGET_KL25Z ) || defined(TARGET_KL46Z) || defined(TARGET_K64F) || defined(TARGET_KL05Z) \ || defined(TARGET_K20D50M) || defined(TARGET_K22F) \ || defined(TARGET_NRF51822) \ || defined(TARGET_RZ_A1H) UIPEthernetClass UIPEthernet(D11, D12, D13, D10); // mosi, miso, sck, cs #endif
Copying it into your program should fix the issue. However, for you it's also sufficient to add just the following single line:
I hope that helped.
Cheers,
Zoltan
