10 years, 3 months ago.
How to send a frame
I'm trying to send a frame. I use this program to connect to a gateway my board. I understand how to configure my DevEui etc... but I don't understand how to send 25 for exemple. I would like to erase the callback too.
Thanks for your help
Rozenn
Hi:
I have been trying to use this code also, and I am in no means an expert of it, so my answer may not be entirely correct!
On the function "static void prepareTxFrame( void )" on Main.c it fills a buffer with datum (the LMIC.frame[x]). I changed those to send "Hello" and I am receiving it correctly on my gateway (in base64 "Hello" is "aGVsbG").
I am not sure what you mean about erasing the callback! Could you elaborate?
I hope it is of help,
-Ed
It didn't work. I think I don't configure well my parameters. to connecte to the gateway I need to configure the device EUI, the device address, the device profile ID, the netwook key and the application Key. But what is AppEui, devKey ?
thanks for your help :)
Rozenn
posted by Rozenn Tassé 25 Nov 2015
The followin PDF has a lot of information that can be of use. See page 30 of this pdf: https://www.lora-alliance.org/portals/0/specs/LoRaWAN%20Specification%201R0.pdf
Some of those values you decide, and others are related to the network and your type of connection. Are you connecting as an end-device connection or an Over The Air connection?
posted by Eduardo Garcia 25 Nov 2015
