10 years, 4 months ago.
"LINK DEAD" Indication
After some time the NAmote gives a "LINK DEAD" indication and appears to stop working.
======== DEBUG STARTED
B: INITFUNC v3 JOINING JOINED Net ID = 0 LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 . . . TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LED1 = 1 TXCOMPLETE LED1 = 0 LINK_DEAD LED1 = 1
Nothing else after this...
Has this "error" been seen before?
It appears to be related to #define CHNL_HYBRID. I am operating with a gateway with a single SX1301 so it was my understanding that I should define CHNL_HYBRID in this configuration. If CHNL_HYBRID is not defined the mote recovers form "LINK DEAD" by re-JOINING.
posted by Greg Davis 24 Nov 2015
LINK_DEAD means it failed to receive a response from a link check request. To keep it trying to rejoin, I had commented out an if block after nojoinframe: in processJoinAccept(). If you want quicker link checking, you can change LINK_CHECK_INIT from -12 to something closer to 0. When LMIC.adrAckReq > 0, the link check is requested.
How does one disable the rejoin process entirely? In many cases it may not be appropriate to give up on the link just because communication is not bi-directional?
posted by Dave Kjendal 25 Nov 2015
