10 years, 4 months ago.
Rx Frequency: 903700000
AT&V shows that Rx Frequency is always 903700000 This is regardless which sub-band I will select for Tx (I am in North America) I am confused as 903700000 is Rx frequency in the 1 sub-band (last band). Could you please explain? W.
The Rx Frequency in the configuration and which is set by the AT+RXF command is not what is used in RX window 1 and 2. The radio frequency used after a send is determined by the transmit frequency and public or private mode. To communicate with the a LoRaWAN gateway the software is setting the Rx parameters to allow communication.
Thanks Jason, this is exactly how I expect it. But still that 903700000 is not clear to me, why is it even there? Are you saying that Rx freq is required to be set to something but then the actual Rx Freq is determine at runtime?
posted by 20 Nov 2015
