10 years, 4 months ago.
Ticker, Timeout or RtosTimer to schedule a function call?
i my project is my target to shedule the call of a funtion. After a delay of 50ms or 100ms a can response shall be send.
The steps are: 1. main(): get the can message by interrupt (RxIrq) and check ID. If valid, pass to messageConsumer_Thread with
queue.put(ptr_msg);
2.in my messageConsumer_Thread inside while(true):
if (evt.status == osEventMessage)
CANMessage *ptr_msg = (CANMessage*) evt.value.p;
switch (ptr_msg->id{
case LOW:
consumeLOW_Message(ptr_msg)
break;
case HIGH:
consumeHIGH_Message(ptr_msg);
break;
3. Inside the void consumeHIGH(consumeLOW)-Function (after setting the payload of the frame):
RtosTimer sendTimer(send_Frame, osTimerOnce, (void *) ptr_msg); sendTimer.start(50); //sendTimer.start(100); if consumeLOW()
4. Atfer 50ms(100ms) the send_Frame-Function shall send the CANFrame (after casting):
if (can2.write(*ptr_msg)) {
memoryPool.free(ptr_msg);
led1 = !led1;
The problems here are: the send_Frame() is never called -> sendTimer dies after exiting consumeHigh? How can i shedule the send job in other way? by a seperate senderThread (passing the Timer to it and keep it alive)? or is a timeout object the better solution?
Can somebody help me with that issue?
Thank you.
