10 years, 4 months ago.
KL26Z programming with CMSIS-DAP on uVision5
I managed to port and successfully compile the mbed sdk for the KL26Z.
However, on my custom board, I'm using the MKL26Z64 (64kB flash, 8kB RAM).
I set up the memory sizes on uVision as:
My scatter file (MKL26Z4.sct) is
LR_IROM1 0x00000000 0xFFFF { ; load region size_region (32k)
ER_IROM1 0x00000000 0xFFFF { ; load address = execution address
*.o (RESET, +First)
*(InRoot$$Sections)
.ANY (+RO)
; 8_byte_aligned(48 vect * 4 bytes) = 8_byte_aligned(0xC0) = 0xC0
; 0x2000 - 0xC0 = 0x1F40
RW_IRAM1 0x1FFFF0C0 0x1F40 {
.ANY (+RW +ZI)
When I try to program with the CMSIS-DAP, the chip is successfully erased and the programming progress bar fills up a bit. Then I get "Programming done." and a
RDDI-DAP Error Error: Flash Download failed - "Cortex-M0+"
I suspect it has something to do with the scatter file, although I'm not sure.
Any help?
Thanks
