10 years, 5 months ago.
"wifi.connect" hang up
By problems such as access point, in a case where the connection destination is no longer, and repeat the initialization of the following, you can hang up in the "wifi.connect" several times. Will there countermeasures like? Nice to meet you. Matsuda
Wifi接続
int Wifi_Connect()
int ret = 0;
Initialize Wi-Fi interface ret = wifi.init(); if(ret != 0){ printf("Wi-Fi initial failed %d\r\n", ret); return ret; } wait(0.5);
ret = wifi.disconnect(); if(ret != 0) { printf("on the disconnect state %d\r\n", ret); return ret; } wait(0.3);
E_SECURITY SecuriryType; if (strcmp(WifiSet.Wifi_SECURITY_TYPE,"WEP")== OK) SecuriryType = e_SEC_WEP; else if (strcmp(WifiSet.Wifi_SECURITY_TYPE,"WPA-PSK(TKIP)")==OK) SecuriryType = e_SEC_WPA_TKIP; else if (strcmp(WifiSet.Wifi_SECURITY_TYPE,"WPA2-PSK(AES)")==OK) SecuriryType = e_SEC_WPA2_AES; else if (strcmp(WifiSet.Wifi_SECURITY_TYPE,"WPA2-PSK(TKIP/AES)")==OK) SecuriryType = e_SEC_WPA2_MIXED; else if (strcmp(WifiSet.Wifi_SECURITY_TYPE,"WPA-PSK(AES)")==OK) SecuriryType = e_SEC_WPA_AES; else SecuriryType = e_SEC_OPEN;
ret = wifi.connect( WifiSet.Wifi_SSID, strlen(WifiSet.Wifi_SSID) , SecuriryType , WifiSet.Wifi_SECURITY_KEY, strlen(WifiSet.Wifi_SECURITY_KEY) ); if(ret != 0) { printf("Connect AP is failed %d\r\n", ret); return ret; } wait(0.5);
DHCPでIPアドレスを取得 int retIp = wifi.setIPConfig(true); wait(0.5); printf("IP Address Get!!! %d\n", retIp);
return(true); }
