10 years, 5 months ago.
USBHostMSD - Add device failed - Freescale K22F with F401RE-USBHost
I try to read/write USB flash disk on FRDM-K22F, the implement source is USBHostMSD in F401RE-USBHost.
I got the error message: [USB_ERR: libs/USBHostMSD/USBHost/USBHost.cpp:56]ADD DEVICE FAILD parent:0 port:0 speed:full VID:9d9f PID:0000 class:e8 addr:1
The return error place is at line 53 in USBHost::addDevice(USBDeviceConnected* parent, int port, bool lowSpeed) of USBHost.cpp:
USBHost.cpp
int rc = controlRead(dev, 0x80, GET_DESCRIPTOR, 1<<8, 0, desc, 8);
USB_TEST_ASSERT(rc == USB_TYPE_OK);
if (rc != USB_TYPE_OK) {
USB_ERR("ADD DEVICE FAILD");
The add device step is at line 132 in USBHALHost::init() of USBHALHost_KL46Z.cpp
// Disable IRQ
NVIC_DisableIRQ(USB0_IRQn);
#if defined(TARGET_K64F)
MPU->CESR=0;
#endif
// choose usb src as PLL
SIM->SOPT2 |= (SIM_SOPT2_USBSRC_MASK | SIM_SOPT2_PLLFLLSEL_MASK);
// enable OTG clock
SIM->SCGC4 |= SIM_SCGC4_USBOTG_MASK;
// USB Module Configuration
// Reset USB Module
USB0->USBTRC0 |= USB_USBTRC0_USBRESET_MASK;
while(USB0->USBTRC0 & USB_USBTRC0_USBRESET_MASK);
// Clear interrupt flag
USB0->ISTAT = 0xff;
// Set BDT Base Register
USB0->BDTPAGE1=(uint8_t)((uint32_t)bdt>>8);
USB0->BDTPAGE2=(uint8_t)((uint32_t)bdt>>16);
USB0->BDTPAGE3=(uint8_t)((uint32_t)bdt>>24);
// Set SOF threshold
USB0->SOFTHLD = USB_SOFTHLD_CNT(1);
// pulldown D+ and D-, enabled
USB0->USBCTRL = USB_USBCTRL_PDE_MASK;
USB0->USBTRC0 |= 0x40;
// Host mode
USB0->CTL |= USB_CTL_HOSTMODEEN_MASK;
// Desable SOF packet generation
USB0->CTL &= ~USB_CTL_USBENSOFEN_MASK;
NVIC_SetVector(USB0_IRQn, (uint32_t)_usbisr);
NVIC_EnableIRQ(USB0_IRQn);
bool lowSpeed = wait_attach();
for(int retry = 2; retry > 0; retry--) {
// Enable RESET
USB0->CTL |= USB_CTL_RESET_MASK;
wait_ms(500);
USB0->CTL &= ~USB_CTL_RESET_MASK;
// Enable SOF
USB0->CTL |= USB_CTL_USBENSOFEN_MASK;
wait_ms(100);
// token transfer initialize
token_transfer_init();
USB0->INTEN |= USB_INTEN_TOKDNEEN_MASK|
USB_INTEN_ERROREN_MASK;
USB0->ERREN |= USB_ERREN_PIDERREN_MASK|
USB_ERREN_CRC5EOFEN_MASK|
USB_ERREN_CRC16EN_MASK|
USB_ERREN_DFN8EN_MASK|
USB_ERREN_BTOERREN_MASK|
USB_ERREN_DMAERREN_MASK|
USB_ERREN_BTSERREN_MASK;
if (addDevice(NULL, 0, lowSpeed)) {
break;
Am I missed any steps? or How can I do further test on the board?
Any advices would be appreciate. Thanks!
