10 years, 4 months ago.
STM32 F4 401RE - interrupt EXTI same code: MBED stop, coide working!
mbed EXTI not working and then i try coide for compare and finding problem
test make blink led more fast when detect interrupt:
- with mbed when interrupt is detect blink led is stop
- with coide when interrupt is detect led blink fast with no problem
Note
- SystemClock_Config(); not working with mbed
COIDE CODE:
COIDE CODE:
#include "stm32f4xx_hal.h"
#include "stm32f4xx_nucleo.h"
static GPIO_InitTypeDef GPIO_InitStruct;
static void SystemClock_Config(void);
static void Error_Handler(void);
int16_t count1 = 1000;
void EXTI0_IRQHandler(void)
HAL_NVIC_ClearPendingIRQ(EXTI0_IRQn);
HAL_GPIO_EXTI_IRQHandler(GPIO_PIN_0);
/* EXTI line interrupt detected */
if(__HAL_GPIO_EXTI_GET_IT(GPIO_PIN_0) != RESET)
__HAL_GPIO_EXTI_CLEAR_IT(GPIO_PIN_0);
HAL_GPIO_EXTI_Callback(GPIO_PIN_0);
void HAL_GPIO_EXTI_Callback (uint16_t GPIO_Pin)
if (GPIO_Pin == GPIO_PIN_0) {
count1 = 100;
HAL_Init();
__HAL_RCC_GPIOA_CLK_ENABLE();
//__GPIOA_CLK_ENABLE();
GPIO_InitStruct.Pin = GPIO_PIN_0; //PA0 as interrupt test
GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FAST;
HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
HAL_NVIC_SetPriority(EXTI0_IRQn, 3, 0);
HAL_NVIC_EnableIRQ(EXTI0_IRQn);
/* -2- Configure PA05 IO in output push-pull mode to
drive external LED */
GPIO_InitStruct.Pin = GPIO_PIN_5;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Pull = GPIO_PULLUP;
while (1) {
HAL_NVIC_DisableIRQ(EXTI0_IRQn);
HAL_GPIO_TogglePin(GPIOA, GPIO_PIN_5);
HAL_Delay(count1);
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitTypeDef RCC_OscInitStruct;
/* Enable Power Control clock */
/* Enable HSI Oscillator and activate PLL with HSI as source */
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.HSICalibrationValue = 0x10;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
RCC_OscInitStruct.PLL.PLLM = 16;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4;
RCC_OscInitStruct.PLL.PLLQ = 7;
if(HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers */
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if(HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
while(1)
MBED CODE
MBED CODE
#include "stm32f4xx.h"
#include "stm32f4xx_hal_gpio.h"
count1 = 100;
HAL_Init();
while (1) {
HAL_Delay(count1);
