10 years, 5 months ago.
UDPSocket_HelloWorld - main.cpp doesn't compile on Seeduino-Arch-Pro
as title
Error: Cannot open source input file "cmsis.h": No such file or directory in "EthernetInterface/lwip-sys/arch/cc.h", Line: 115, Col: 20
10 years, 4 months ago.
Import it as a library then select it from the list compiles fine... to do this when you compile there is message in the errors list with a cool button says fixit then it will ask you to select it from the library.
I just tried it so I know this works
