10 years, 5 months ago.
FRDM-K22F serial output freezing
I have a program that outputs data to a terminal program that runs fine for a few minutes, but then the serial interface hangs. I have tried 2 different serial port applications (Putty and Realterm) on my Windows laptop (It does this in Windows 7 and Windows 10) and they both act the same way. I have to close the port in RealTerm and open it again in order to get the data to start flowing again. Any suggestions?
This is some strange behavior afaik, have you tried on a different computer ?
Are you outputting a lot of data with the serial port ?
If you can make a minimal example of your code I can try to run it on a KL25Z
Thanks. I'm running it on a different PC now and so far, so good. I'm averaging a little less than 800 characters per second, but it was also happening at lower data rates.
posted by Adrian Adamson 24 Oct 2015
