10 years, 4 months ago.
Do this work program work on FRDM-KL46Z?
I have upload this program to my board but when i run it in the terminal the menu doesn't appear
I've just re-imported my program and ran on FRDM-KL46Z and it is working fine.
A few things, I'd like you to check are
(1) baud rate is 115200 (instead of default 9600)
(2) to see what you are typing, please set "local echo"
(3) to avoid new line problem, if you are using Tera Term Pro, 4.8x,
please set New-Line -> Receive -> AUTO
(4) Meantime please check if PTE30 are generating a sin-wave 3.0V(P-P) 1kHz.
Note: Although I have not tested, probably "Japanese" nor "Kanji" are required.
Best Regards, 23-Aug-2015 moto
Thank you very much Moto, I've already make it work and it works really fine, it's just that didn't check the port properties and the baud rate was 9600, but what I wanted to know is how to see what I'm typing and now everything works great. Thank you very much for answering you have solved all my doubts.
Saludos
posted by 23 Oct 2015
