10 years, 4 months ago.
ADC uint16_t in LPC1768
Hey guys!.
I've made the code that measure ADC value and voltage using addValue.
And I'd like to know that whether [ I can use uint16_t code at LPC1768 ] and [ how to get 12bit value ]. (I know if I AnalogIn function, that data come out as the 0 ~ 1 values and it is much easier way than what I'm doing now)
The problem is.. if I used the uint16_t function and .read_u16() function, I've got the right value(maximum adcValue is 65535 and minimum is 0). However, when I changed the code from {.read_u16()} to {.read_u16()&0xFFF}, I got the wrong answer.
I was so confused because LPC1768 has the 12-bit ADC. How is this possible?. If you know about [ .read_u16() function ], please let me know.
my code is like this.
1. 16-bit adcValue(I've got right one)
- include "mbed.h"
AnalogIn adc(p20);
Serial pc(USBTX,USBRX);tx,rx
uint16_t adcValue;
float voltage;
adcValue = adc.read_u16(); //
voltage = adcValue * 3.3 /65535; 2^16 = 65536
pc.printf("ADC Value : %i, %.3f volt \r\n", adcValue,voltage);
wait(0.1);
2. 12-bit adcValue(I've got wrong answer)
- include "mbed.h"
AnalogIn adc(p20);
uint16_t adcValue;
float voltage;
adcValue = adc.read_u16()&0xFFF;
voltage = adcValue * 3.3 /4095; 2^12 = 4096
wait(0.1);
Thanks!
