10 years, 5 months ago.
Flip the G sensor
Is both the X and Y sensors used for nudging? Or just the one axis as configured in the config? ie just an inline nudge along one axis or do you compute a diagonal nudge if its pushed from a corner?
I ask this because I would like to mount the controller upside down in my cabinet ie one axis would be flipped. I built my cabinet with a large removable door in the base and a false panel about half way up (in line with the base) that holds the solenoids & electronics etc all mounted on the underside. This makes it very easy to work on everything without removing the main monitor (just lay on the floor like service a vehicle).
Thanks. Ray.
