9 years, 11 months ago.
Struggling to get updates from this library
So I'm trying to get this library working on my Happy Gecko dev board (first ever cortex development). I used the MemLCD-Temperature-Humidity-Demo as an example. I get the first temperature reading over serial, but each reading after is exactly the same value. Only after you hit reset on the board you get a real up to date reading from the sensor.
I'm calling the rhtSensor.measure method and waiting for the callback until I call rhtSensor.get_temperature() but it's never different. Am I doing something stupid here?
#include "SILABS_RHT.h" DigitalOut status(LED1); // Status LED 1 Serial serial(USBTX, USBRX); // Setup USB serial // Setup sensor I2C sensorI2C(PD6, PD7); DigitalOut SENS_EN(PC8); silabs::SILABS_RHT rhtSensor(&sensorI2C); // Variables volatile bool busChecked = false; // Functions void respondedCallback(void) { busChecked = true; } int getTemp(void) { status = 1; // Turn on status LED busChecked = false; rhtSensor.measure(si7021, respondedCallback); while(busChecked == false) sleep(); while(rhtSensor.get_temperature() == 0); status = 0; // Turn on status LED return rhtSensor.get_temperature(); // return rhtSensor.get_humidity() } int main() { SENS_EN = 1; // Enable sensor wait(1); rhtSensor.check_availability(si7021, respondedCallback); while(busChecked == false) sleep(); while(1) { serial.printf("%02d.%01d\n", getTemp() / 1000); wait(3); } }
