10 years, 4 months ago.
NTPClient reads Fri 01-Jan-2066 02:00:00
NTPClient reads Fri 01-Jan-2066 02:00:00 (or 00:00:00), or it hangs reading the time.
Reading time: [NTPClient : DBG]Time is set to (UTC): Fri Jan  1 00:00:00 2066
[NTPClient : DBG]Binding socket
[NTPClient : DBG]Ping
[NTPClient : DBG]Pong
I use cc3000 on DISCO-F746NG. From the laptop, I can ping the NTP server, and I tried to retrieve the time from several NTP servers, with no luck.
It appears if DUBUG is enabled it never hangs, but comes with a wrong date and time. If it is disabled, it often hangs.
What could be the problem?
    // Read time from server
    NTPClient ntp_client;
    // NTP Server Parameters
//    char* domain_name = "217.114.59.3";
    char* domain_name = "2.nl.pool.ntp.org";
//    char* domain_name = "0.uk.pool.ntp.org";
    int   port_number = 123;
    time_t ct_time;
    char time_buffer[80];
    char time_buffer_old[80];
    printf("Reading time: ");
    if (ntp_client.setTime(domain_name, port_number) == 0) {
        printf("Passed.\r\n");
        ct_time = time(NULL) + 7200; // Summer time - Convert to Europe/Amsterdam Time
        set_time(ct_time);
        strftime(time_buffer, 80, "%a %d-%b-%Y %T", localtime(&ct_time));
        printf("Time            : %s\r\n", time_buffer);
    } else {
        printf("FAILED!\r\n");
