10 years, 6 months ago.
Linker error using Keil uVision4
How to resolve the below. I got it when i try to compile the example code of mDot board from the website itself as per guidelines given as well.
linking... test.axf: Error: L6320W: Ignoring entry command. Cannot find argument 'Reset_Handler'. test.axf: Warning: L6320W: Ignoring first command. Cannot find argument 'Vectors'. Target not created
Our UDK programming board uses the same programming chip as on the ST-Link. I do not see why it couldn't work if you have the pins wired correctly.
posted by Jason Reiss 09 Oct 2015
Which example are you trying to compile?
Did you export the code from the mbed.org?
Keil uVision4 is not a currently supported export toolchain, which toolchain did you choose?
I didn't export the code, i just downloaded and followed the steps to use Keil
posted by mb s 09 Oct 2015
Hi, I tried to port "helloworld demo code" on mDot board code using ST-Link debugger. I compiled the code using IAR Ver7.40, but still i am unable to update code as I am getting Fatal error as "ST-Link, No MCU device found", how can i resolve the error? Is there any way to update code mDot board except using Debug/USB pins. ST_Link connected as
ST-Link pin no - mDot board pin nos SWIO (pin 7) - 27 SWCLK (pin 9) - 26
ST-Link 1 & 19 are shorted.
