11 years, 2 months ago.
XBee interaction with EthernetInterface & RTOS
/media/uploads/BPPearson/xbee_ethernetinterface_issue.txt
Check your wiring: XBee RX to mbed TX and XBee TX to mbed RX. GND and +3.3V connected?
Check XBee Configuration: baud rate? API mode?
posted by BlazeX . 31 Jan 2015
I am using the LPC4088 board so the XBee is plugged into the header on the chip. Also, it works fine until I enable the EthernetInterface which requires the RTOS.
posted by Brian Pearson 31 Jan 2015
