10 years, 5 months ago.
How to get Keil or Emblocks to compile and or upload this project...
The project compiles fine and works on the homepage:
Import programBLE_HTM_by_InTempSensr_working_copy_lib_updated
Test for export ti uv2/emblocks
But when i export it to keil i get an error it can not export - but i get the zip Then when opened in keil it gives an error about device not found if i ignore and update to uv5 project - select the right device under keil it will not compile if i ignore this and donøt set a device it will compile fine - but i can not download from keil with jlink (have not checked if the output is working)
What am i doing wrong?
/Rapzak
