10 years, 5 months ago.
How to switch between different data rates?
#include "ADXL345_I2C.h"
#include "CheckRTC.h"
ADXL345_I2C accelerometer(D14, D15);
//Serial pc(USBTX,USBRX);
Serial pc(D8, D2);
pc.baud(115200);
int readings[3] = {0, 0, 0};
time_t seconds;
char buf[64];
struct tm t;
t.tm_year = 15 + 100;
t.tm_mon = 10 - 1;
t.tm_mday = 07;
t.tm_hour = 14;
t.tm_min = 27;
t.tm_sec = 00;
seconds = mktime(&t);
set_time(seconds);
pc.printf("Starting ADXL345 test...\n");
wait(.001);
pc.printf("Device ID is: 0x%02x\n", accelerometer.getDeviceID());
wait(.001);
// These are here to test whether any of the initialization fails. It will print the failure
if (accelerometer.setPowerControl(0x00)){
pc.printf("didn't intitialize power control\n");
return 0; }
//Full resolution, +/-16g, 4mg/LSB.
wait(.001);
if(accelerometer.setDataFormatControl(0x0B)){
pc.printf("didn't set data format\n");
return 0; }
wait(.001);
//3.2kHz data rate.
//Measurement mode.
if(accelerometer.setPowerControl(MeasurementMode)) {
pc.printf("didn't set the power control to measurement\n");
return 0; }
switch ( int i = 7 ) {
case 1:
accelerometer.setDataRate(ADXL345_3200HZ);
break;
case 2:
accelerometer.setDataRate(ADXL345_1600HZ);
break;
case 3:
accelerometer.setDataRate(ADXL345_800HZ);
break;
case 4:
accelerometer.setDataRate(ADXL345_400HZ);
break;
case 5:
accelerometer.setDataRate(ADXL345_200HZ);
break;
case 6:
accelerometer.setDataRate(ADXL345_100HZ);
break;
case 7:
accelerometer.setDataRate(ADXL345_50HZ);
break;
case 8:
accelerometer.setDataRate(ADXL345_25HZ);
break;
case 9:
accelerometer.setDataRate(ADXL345_12HZ5);
break;
case 10:
accelerometer.setDataRate(ADXL345_6HZ25);
break;
int i = 1;
while (1) {
seconds = time(NULL);
strftime(buf,40, "%I:%M:%S %p (%Y/%m/%d)", localtime(&seconds));
accelerometer.getOutput(readings);
i++;
pc.printf("\n\r %i, %i, %i %d", (int16_t)readings[0], (int16_t)readings[1], (int16_t)readings[2], i);
pc.printf(" %s\r\n",buf);
