10 years, 6 months ago.
Text OLED Display and TextLCD Library
I'm trying to get a two line OLED Display working with a KL25Z, I have a similar LCD display working correctly.
I'm trying to tell the TextLCD library to use the WS0010 controller chip but I can't figure out what I'm doing wrong.
Me code is:
// Hello World! for the TextLCD
#include "TextLCD.h"
TextLCD lcd(D0,D1,D2,D3,D4,D5, TextLCD::LCD16x2, TextLCD::WS0010 ); // 4bit bus: rs, e, d4-d7
    lcd.printf("Hello World!\n");
To which I get the error message:
Error: No instance of constructor "TextLCD::TextLCD" matches the argument list in "main.cpp", Line: 5, Col: 14
You are using the Bus interface constructor. In this case the parameter list includes default parameters for the backlight and for the second enable line.
TextLCD lcd(p15, p16, p17, p18, p19, p20);  // RS, E, D4-D7, LCDType=LCD16x2, BL=NC, E2=NC, LCDTCtrl=HD44780
When you want to select a different controller than the default HD44780 and you explicitly select the LCDType then you also need to provide the dummy parameters for BL and E2. This is needed because C/C++ does not allow skipping of default parameters unless they are at the end of the parameter list. Try this:
TextLCD lcd (D0, D1, D2, D3, D4, D5, TextLCD::LCD16x2, NC, NC, TextLCD::WS0010 ); // 4bit bus: RS, E, D4-D7, LCDType=LCD16x2, BL=NC, E2=NC, LCDTCtrl=WS0010
BTW, I didnt check for the KL25Z but many arduino like boards dont use D0 and D1. The pins are use for the serial debug port to the host PC.
