10 years, 6 months ago.
mDot output power
The range for the AT+TXP command is 2-20. I'm trying to understand which 1272 PA is used by libmdot. The mDot spec sheet says the maximum North American output s +17 dBm; what happens when you set +TXP to 18, 19, or 20? Which 1272 PA is used for which +TXP setting? Does the mDot enforce the 1% duty cycle when +20 dBm is used (assuming PA_BOOST is actually used)?
Thanks.
