10 years, 6 months ago.
wifi library
Hello.
I cant connect netwrok, I would like to use DHCP.
Could you open all source code - mbed, wifi lib ?
Thanks.
https://developer.mbed.org/teams/components/code/WiflyInterface/#fc3d86645d23
Thank you for your qucik response. However, i cannot connect network. it doesnt seem that it can change cmd mode. I guess it cannot connect the wifi board to ST32F401. Could you let me know how to connect (cannot use D2,D3 because I cant remove some parts with solder so need to use arudino path D0, D1) ? Thanks.
posted by 01 Oct 2015The RX and TX pins can be configured on the hardware. Details in the hardware section in https://developer.mbed.org/components/Seeed-Wifi-Shield/
posted by 02 Oct 2015
