10 years, 6 months ago.
Disable SoftSerial Interrupt
You can enable Serial or SoftSerial with:
code snippet 1
serialDevice.attach(&rxInterrupt,Serial::RxIrq); //or
serialDevice.attach(&rxInterrupt,SoftSerial::RxIrq);
Then, you can disable the interrupt in Serial with:
code snippet 2
NVIC_DisableIRQ(USART2_IRQn);
But, how do you that with SoftSerial?
How do you disable SoftSerial Interrupt?
What reference should I point to?
Thanks for your time
Currently it is not possible to disable the internal interrupts used for SoftSerial: The result would be that it stops functioning properly, since contrary to normal Serial, it requires interrupts to receive/transmit data.
However if you just want to disable interrupts going to your program, use:
serialDevice.attach(NULL,SoftSerial::RxIrq);
That should work.
