10 years, 6 months ago.
Blinky does not work
Hi, i tried to get on with blinky. Nothing happens white and blue led are permanent on.
Xadow m0 is shown in finder under osx - so far so good. Deleting firmware.bin and writing new compiled file works. Reset button pressed and nothing happens.
Any ideas ?
brgds pici
i had the same problem but 1. copy .bin to flash 2. disconnect usb 3. connect usb - works
or 3. connect accu 4. press reset - works
Thanks Peter, actually that did not work for me. What works for me is to copy the new bin from my Downloads folder to Xadow via terminal: cp -X xadow*.bin /Volumes/CRP\ DISABLD/firmware.bin
Thank you for your help. brgds
posted by 05 Oct 2015maybe you can help me i am a newbee i can not make a serial connect to my xadow m0 because i can not install the serial.inf on my win 7 and so have no virtual com port my device manager do not show a unknown device only the flash drive
thanks
posted by 05 Oct 2015sorry Peter. I am an Apple user and not familiar with Windows. May be you find some help here: http://www.seeedstudio.com/forum/viewforum.php?f=43&sid=d37a4df3371ab2e19d559e617ec4ceda
I am having a similar problem with Linux. I can delete firmware.bin, copy my bin to the device, unmount the device, mount it again and my file is in place. However, after a reset or power-off it goes back to firmware.bin. Any suggestion?
posted by Joe Kirby 18 Dec 2015Follow up to my comment. Please refer to NXP application note AN11305 - "USB In-System Programming with the LPC11U3x/LPC11U2z"
