10 years, 2 months ago.
Frequency / channel configuration
Hi
Due to differences in the regulatory environment in Australia, the 900 MHz ISM band is defined between 915.0 and 928 MHz (902-915 is part of the GSM-900 cellular band).
Is it possible to use libmDot configure a device to use Lora via channels defined within this range?
Thanks
Frank
Hi Frank,
We don't currently support a configuration that operates in the Australian (915 - 928) band because that frequency band isn't currently in the LoRaWan 1.0 spec.
The mDot library will allow you to manually set the TX and RX frequencies to values in that range, but your gateway will also need to be configured to operate in that range. Depending on the gateway you're using, this may not be possible.
Cheers,
Mike
