10 years, 6 months ago.
The example code is giving me compiler error 20 and I have no idea why
I literally just imported the library exactly as it is, updated the mbed repository, and it gave me this: http://imgur.com/rZs0YTo
Errors contained in image: Error: Identifier "p15" is undefined in "main.cpp", Line: 6, Col: 14 Error: Identifier "p16" is undefined in "main.cpp", Line: 6, Col: 19 Error: Identifier "p17" is undefined in "main.cpp", Line: 6, Col: 24 Error: Identifier "p18" is undefined in "main.cpp", Line: 6, Col: 29 Error: Identifier "p19" is undefined in "main.cpp", Line: 6, Col: 34 Error: Identifier "p20" is undefined in "main.cpp", Line: 6, Col: 39
Code used:
<code>
  1. include "mbed.h"
  2. include "TextLCD.h"
TextLCD lcd(p15, p16, p17, p18, p19, p20, TextLCD::LCD20x4); rs, e, d4-d7
int main() { lcd.printf("Hello World!\n"); } </code>
Compiler error 20 tells me "The compiler doesn't recognize the name of a variable or class you are trying to reference", The class is referenced in TextLCD.h;
<code> class TextLCD : public Stream { public:
/ LCD panel format */ enum LCDType { LCD16x2 /< 16x2 LCD panel (default) */ , LCD16x2B /< 16x2 LCD panel alternate addressing */ , LCD20x2 /< 20x2 LCD panel */ , LCD20x4 /< 20x4 LCD panel */ };
/ Create a TextLCD interface
  • @param rs Instruction/data control line
  • @param e Enable line (clock)
  • @param d0-d3 Data lines
  • @param type Sets the panel size/addressing mode (default = LCD16x2)
  • / TextLCD(PinName rs, PinName e, PinName d0, PinName d1, PinName d2, PinName d3, LCDType type = LCD16x2);
  1. if DOXYGEN_ONLY / Write a character to the LCD
  • @param c The character to write to the display
  • / int putc(int c);
/ Write a formated string to the LCD
  • @param format A printf-style format string, followed by the
  • variables to use in formating the string.
  • / int printf(const char* format, ...);
  1. endif
/ Locate to a screen column and row
  • @param column The horizontal position from the left, indexed from 0
  • @param row The vertical position from the top, indexed from 0
  • / void locate(int column, int row);
/ Clear the screen and locate to 0,0 */ void cls();
int rows(); int columns();
protected:
Stream implementation functions virtual int _putc(int value); virtual int _getc();
int address(int column, int row); void character(int column, int row, int c); void writeByte(int value); void writeCommand(int command); void writeData(int data);
DigitalOut _rs, _e; BusOut _d; LCDType _type;
int _column; int _row; };
  1. endif </code>
Maybe my programming is rusty, and this is probably something really obvious, but I'm just not getting what is wrong. Can anyone help? Thanks!
It looks you are using the NUCLEO-F103RB board.
The pin names, p15..20, are for the LPC1768 board.
Why don't you try the pin names of the NUCLEO-F103RB board, such as Px_x, Dx or Ax?
That did it, thanks! I appreciate the help, that was driving me nuts. I'm still very new to microcontrollers, and I had just assumed that the names were variables and didn't matter what they were named, I didn't realize that they were keywords for the various pins and specific to each board. My project now moves on!
posted by Matthew Kovach 22 Sep 2015
7 years, 2 months ago.
u need to fix the error with FIX IT command :)
