10 years, 6 months ago.
STM32L4 Stack and Heap overlap (Disco)
For the new STM32L4 I found out a major problem, the first 4k of the heap overlap with the stack!
A few lines diag program can be found here: https://developer.mbed.org/users/Helmut64/code/StackHeapCodeDataInfo/file/29ed9d142ea8/main.cpp
main=0x080039b5 data=0x20000188 stack=0x20000b80 heap=0x20000418-0x20001418 (first 4k via new char[4096] overlaps with the stack)
The STM32L4 MCU has two memory areas:
SRAM2 (32k) @0x10000000 (with max. performance, hardware parity check, retained in standby mode)
SRAM1 (96k) @0x20000000 (the size may decrease/increases with newer L4 MCU modules)
I recommend to use the SRAM2 for the stack and as well for the heap and the heap should continue using SRAM1.
I figured out existing problem on the STM32L4 Disco board, the same problem may exists on the STM32L4 Nucleo board.
Thank you for looking into it.
Thanks for reporting. This might be better track on github as an issue as the development is happening there. We can assign/label presons who gets notifications for example.
Hi Martin, I cloned mbedmicro/mbed.git, however where can I file bugs? Is there a Bugzilla or other tracking system? Thank you, regards Helmut
posted by 22 Sep 2015Hi Martin, I believe I found the problem in startup_stm32l476xx.s (Disco & Nucleo)
The following line must be inserted/changed: (TOOLCHAIN_ARM_STD + TOOLCHAIN_ARM_MIKRO) initial_sp EQU 0x20018000 ; Top of RAM1 96k
This would at least enable the 96k of RAM1, however there is another 32k SRAM2 at 0x10000000-0x10008000
An initial fix would be appreciated.
Regards Helmut
posted by 23 Sep 2015
