10 years, 6 months ago.
mbed-rtos conflict with mbed-CAN
I have an application running on an LCP4088 that uses it's CAN interface. The software to access the CAN interface is the stock routines in mbed-CAN. I need to get this software communicating over ethernet. Ethernetlibrary has mbed-rtos as a dependancy.
The mere act of dropping the mbed-rtos library into the project causes the CAN interface to stop working.
This is a rather major issue for me. It seems that rtos is re-writing some of the existing mbed library routines. (wait in particular)
Is there any known work around for this issue. Is there any known ethernet library that works with a '4088 that does not need the rtos library?
