10 years, 6 months ago.
pin problem ..showing wrong voltages
I made one of the pin high ...and i measured the voltage...it was around 3.3v....later i made the pin low...the voltage was 0....later again i made the pin high...it is showing 0 volts........wt is the problem
- include "mbed.h"
DigitalOut myled(PTE4);
int main() { myled=1; //
while(1) { myled = 1; wait(0.2); myled = 0; wait(0.2); } }
Hi vishwas,
When you post some code, please use <<<<code>>>> tags (look at editing tips).
Code from vishwas
include "mbed.h"
myled=1;
while(1)
myled = 1;
wait(0.2);
myled = 0;
wait(0.2);
Regarding your question, what is the board that you are using with this example code?
Cheers, Miloje
