10 years, 7 months ago.
export program toolchain gcc arm
Hi all,
when I try to export program I can only choose between Emblocks and zip archive, the other options are disabled. Any idea why this happens?
I would like to export programs in order to compile them with gcc arm toolchain
the target I'm choosing is RedBearLab BLE Nano
Thanks in advance
Luca
/media/uploads/xcottos/screen_shot_2015-09-01_at_17.24.50.png
Not every plattform is supported by every toolchain. For your target other exporter then these two are not available at the moment.
Olaf
Thank Olaf.
I was wondering if you could point me out a way to compile a simple BLE project having as target the RedBearLab BLE Nano using the arm gcc toolchain.
I successfully recompiled the mbed SDK (https://github.com/mbedmicro/mbed) for that target and I'm able to recompile the tests (that don't contain any BLE examples), however the build process relies on python scripts while I would like to use the standard make
thank you
Luca
posted by Luca Tamburrano 01 Sep 2015
Luca, there are some options, you can use my simple makefile for mbed : https://github.com/0xc0170/mbed_gcc_makefile, which you can edit to get BLE add.
There's cmake (search for cmake mbed), where is also BLE added.
I am currently adding cmake to project generator (then u can export to makefile and build). I can create one example using BLE and mkit.
posted by Martin Kojtal 02 Sep 2015
