10 years, 7 months ago.
Nucleo STM32F10RB
Can pins D0 and D1 be used as digital input/output?
Pins D0 and D1 are not connected by default. The port pins PA_2 and PA_3 are reserved for the serial port connection to the host PC. Those pins are therefore connected to the STLink interface part of the nucleo board. You could reconnect PA_2 and PA_3 to D0 and D1, disconnect the STLink interface board and then use the pins for Digital I/O. Obviously you will then loose the serial port to the host. Checkout the schematic for the jumper bridges that you need to connect and disconnect to make this possible.
Thank you Wim for your comprehensive answer.
posted by Bruce Mehrdadi 25 Aug 2015
