10 years, 7 months ago.
LEDBlinky and Rotation
First of all may I just say a huge thank you for your work, I wonder if you could answer the following points?
I have the controller happily running in my cabinet in tandem with the CCD plunger using all the functions all is well until I run the LEDBlinky program (http://www.ledblinky.net/ledblinky.htm) in audio detect mode to make my LEDs flash to sound in Pinball FX2. At this point the Pinscape plunger reverses direction? I have the active launch button code running mimicking the Zeb launch idea and looking at the controller using the windows 7 x64 devices properties everything works other then the flipped Z axis. I'm only using your calibration tool and I have not calibrated the controller in windows.
The second question is more of a request, would it be possible to offer an option in the config.h file to rotate the board so it can be positioned with the connectors facing the left of the board at all please?
Many thanks,
Mark
