10 years, 6 months ago. This question has been closed. Reason: Duplicate question
Does the BlueNRG shield work with Nucleo-L053R8? (Problems with btle_init)
I am trying to bring up the basic heart rate example using a BlueNRG shield on a Nucleo-L053. From the logs it looks like the code is always stuck at btle_init>>. From the forums, I noticed that led1 may have a conflict with SPI so I removed that code. But there is still no improvement.
Tracing this further, I see that the problem happens just around the following code in btle.cpp: /* Delay needed only to be able to acces the JTAG interface after reset if it will be disabled later. */ Clock_Wait(500);
/* Initialize the BlueNRG SPI driver */ BNRG_SPI_Init();
Do I need to change any of the SPI init logic or GPIO configuration to get the BlueNRG to work with the Nucleo-L053? Or is it sufficient to just recompile the image for my platform via MBED?
Also, this is after the hardware trick suggested in: https://developer.mbed.org/questions/5694/stuck-on-btle_init/
Note: I did not change the BlueNRG board - I connected pins 11 and 31.
Any help is most appreciated!
Thank you!
Joe
Also, I did follow the shorting of pins 11 and 31 as suggested in https://developer.mbed.org/questions/5694/stuck-on-btle_init/.
But init is still stuck!
posted by J K 20 Aug 2015
