10 years, 4 months ago.
cc3000_hostdriver_mbedsocket combined with SDFileSystem not working
Hi mbed-friends,
If I only use SDFileSystem or cc3000_hostdriver_mbedsocket in a project, they work, so the configurations seems right for each. But if I use them together in the same project it doesn't work. It does not matter if they share the same SPI bus or use different SPI busses.
I use a Adafruit Wifi Shield (cc3000) which also has an SD card slot on it used on SPI1. The platform is an Seeed Arch Max, which also has an SD card slot on SPI2. I tested cc3000_hostdriver_mbedsocket in together with either SD card slot (SPI1 or SPI2).
Has anybody been successful to let both libraries work in one project? Any help is much appreciated. I will also try to print more information to debug it.
/* mbed Microcontroller Library
* Copyright (c) 2006-2013 ARM Limited
* Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
#include "SDFileSystem.h"
#include "cc3000.h"
#include "main.h"
#include "NTPClient.h"
#define CC3000_IRQ D3
#define CC3000_EN D5
#define CC3000_CS D10
#define CC3000_MOSI D11
#define CC3000_MISO D12
#define CC3000_SCLK D13
#define SD_CS D4
#define SD_MOSI D11
#define SD_MISO D12
#define SD_SCK D13
#define SSID "Prakjaroen"
#define PHRASE "A4B5C6D7E8F9"
#define SECURITY WPA2
#define IP "192.168.2.165"
#define MASK "255.255.255.0"
#define GW "192.168.2.1"
#define DHCP 0
#define STATIC_IP 1
#define IP_INIT DHCP
//SDFileSystem sd(SD_MOSI, SD_MISO, SD_SCK, SD_CS, "sd"); // the pinout on the mbed
using namespace mbed_cc3000;
// cc3000 wifi(irq, en, cs, SPI(mosi, miso, sclk), SSID, PHRASE, WPA2, false);
// +5V VCC 5V +5V
// GND GND GND GND
// D8 INT Interrupt PA_9
// D9 EN WiFi Enable PC_7
// D10 CS SPI Chip Select PB_6
// D11 MOSI SPI MOSI PA_7
// D12 MISO SPI MISO PA_6
// D13 SCK SPI Clock PA_5
/* cc3000 module declaration specific for user's board. Check also init() */
#if (MY_BOARD == WIGO)
cc3000 wifi(PTA16, PTA13, PTD0, SPI(PTD2, PTD3, PTC5), SSID, PHRASE, SECURITY, false);
Serial pc(USBTX, USBRX);
#elif (MY_BOARD == WIFI_DIPCORTEX)
cc3000 wifi(p28, p27, p30, SPI(p21, p14, p37), SSID, PHRASE, SECURITY, false);
Serial pc(UART_TX, UART_RX);
#elif (MY_BOARD == MBED_BOARD_EXAMPLE)
cc3000 wifi(CC3000_IRQ, CC3000_EN, CC3000_CS, SPI(CC3000_MOSI, CC3000_MISO, CC3000_SCLK), SSID, PHRASE, SECURITY, false); //SparkFun Board on Arduino pin definitions
//Serial pc(USBTX, USBRX);
// Serial pc(P4_28, P4_29);
#if defined TARGET_NUCLEO_F411RE
#elif defined(TARGET_ARCH_PRO)
#elif defined(TARGET_ARCH_MAX)
Serial bt(D6, D7); // tx, rx, Arch Max
#elif defined(TARGET_LPC4337)
Serial pc(P2_10, P2_11); // TX, RX
#else
#endif
#else
#endif
// array to store RM parameters from EEPROM
unsigned char cRMParamsFromEeprom[128];
// array to store MAC address from EEPROM
unsigned char cMacFromEeprom[6];
* \brief NTP client demo
* \param none
* \return int
uint8_t firmware_ver[2];
signed char mac_status = -1;
unsigned char FW_status = 1;
init(); /* board dependent init */
pc.baud(230400);
bt.baud(9600);
printf("\r\nCombining cc3000 and SDFileSystem on same or different SPI bus.\r\n");
printf("Target : ");
printf("NUCLEO F411RE\r\n");
printf("Seeed Arch PRO\r\n");
printf("Seeed Arch Max\r\n");
printf("LPC4337\r\n");
#else
printf("Unknown\r\n");
#endif
printf("CPU Clock: %3.3f MHz\r\n", ((float)SystemCoreClock/1000000.0));
printf("MAC : ");
char mac_board[6];
mbed_mac_address(mac_board);
for(int i=0; i<6;i++) {
printf("%02X", mac_board[i]);
if (i < 5) printf(":");
printf("\r\n");
#if (IP_INIT == STATIC_IP)
printf("Initialize the interface with a static IP address...\r\n");
wifi.init(IP, MASK, GW);
#else
printf("Initialize the interface with DHCP...\r\n");
wifi.init();
#endif /* STM32F10X_CL */
// SD Card:
printf("SD Card test\r\n");
mkdir("/sd/mydir", 0777);
printf("Directory /sd/mydir created\r\n");
FILE *fp = fopen("/sd/mydir/sdtest.txt", "w");
if(fp == NULL) {
printf("Could not open file /sd/mydir/sdtest.txt for write\r\n");
fprintf(fp, "The quick brown fox jumps over the lazy dog.\r\n");
fclose(fp);
printf("File /sd/mydir/sdtest.txt written!\r\n");
// CC3000:
printf("CC3000 test\r\n");
printf("Read from cc3000...\r\n");
// Read Firmware Version and MAC Address
FW_status = wifi.read_sp_version(firmware_ver); // read actual Firmware version
if(FW_status == 0){
printf("Firmware version: %d.%d\r\n", firmware_ver[0], firmware_ver[1]);
mac_status = wifi.get_mac_address(cMacFromEeprom);
if(mac_status == 0){
printf("MAC address : ");
for(int i = 0; i < 6; i++) {
printf("%02X", cMacFromEeprom[i]);
printf("\r\n");
} else {
printf("ERROR: CC3000 not found - check connections !\r\n");
// WiFi parameters
printf("WiFi parameters:\r\n");
printf("SSID : %s\r\n", SSID);
printf("Phrase : %s\r\n", PHRASE);
printf("Security : ");
if (SECURITY == 0) printf("NONE");
if (SECURITY == 1) printf("WEP");
if (SECURITY == 2) printf("WPA");
if (SECURITY == 3) printf("WPA2");
printf("\r\n");
// Connect to WiFi
printf("Bring the interface up...\r\n");
if (wifi.connect(30000) == -1) {
printf("ERROR: Failed to connect. Please verify connection details and try again.\r\n");
char *ip = wifi.getIPAddress();
char *mask = wifi.getNetworkMask();
char *gate = wifi.getGateway();
char *mac = wifi.getMACAddress();
bool conn = wifi.is_connected();
bool dhcp = wifi.is_dhcp_configured();
bool enabled = wifi.is_enabled();
printf("IP : %s\r\n", ip);
printf("Netmask : %s\r\n", mask);
printf("Gateway : %s\r\n", gate);
printf("MAC : %s\r\n", mac);
printf("Connected : %d\r\n", conn);
printf("DHCP : %d\r\n", dhcp);
printf("Enabled : %d\r\n", enabled);
// Read time from server
NTPClient ntp_client;
// NTP Server Parameters
char* domain_name = "0.nl.pool.ntp.org";
int port_number = 123;
time_t ct_time;
char time_buffer[80];
char time_buffer_old[80];
printf("Reading time: ");
if (ntp_client.setTime(domain_name, port_number) == 0) {
printf("Passed.\r\n");
ct_time = time(NULL) + 7200; // Summer time - Convert to Europe/Amsterdam Time
set_time(ct_time);
strftime(time_buffer, 80, "%a %d-%b-%Y %T", localtime(&ct_time));
printf("Time : %s\r\n", time_buffer);
} else {
printf("FAILED!\r\n");
strcpy(time_buffer_old, "Dummy value");
ct_time = time(NULL);
if (strcmp(time_buffer, time_buffer_old) != 0) {
strcpy(time_buffer_old, time_buffer);
printf("%s\r\n", time_buffer);
bt.printf("%s\r\n", time_buffer);
strftime(time_buffer, 80, "%T", localtime(&ct_time));
// 21:00:00
if ((time_buffer[3] == '0') && (time_buffer[4] == '0') &&
(time_buffer[6] == '0') && (time_buffer[7] == '0')) {
// Sync once per hour
set_time(ct_time);
} else {
wait(0.1);
Hangs here:
Target : Seeed Arch Max CPU Clock: 168.000 MHz MAC : 00:02:F7:F0:00:00 Initialize the interface with DHCP...
I haven't tested this. We know cc3000 is sensitive to timing so there might be a problem there (my initial guess). If you pinpoint the problem, please share.
posted by Martin Kojtal 02 Sep 2015Thanks Martin. Time is limiting me at the moment, hence I postponed narrowing down the problem, a bit. I would best start trying other platforms.
posted by Jack Berkhout 18 Sep 2015
