10 years, 6 months ago.
Error: Object of abstract class type "SDFileSystem" is not allowed in "main.cpp"
  1. include "mbed.h"
  2. include "SDFileSystem.h"
SDFileSystem sd(D11, D12, D13, PB_6, "sd"); MOSI, MISO, SCLK, SSEL
int main() { FILE *fp = fopen("/sd/mbed.txt", "w"); fprintf(fp, "Hello World!\n"); fclose(fp); }
Re-import SDFileSystem, do not enable the 'update all sub libraries to latest version'. Then it shoudl work (or at least that fixed it in the past).
Yes,it's working. Now I'm looking to store the 3-axis sensor values with time stamp. 100 samples per second. But now it is not working.
  1. include "ADXL345_I2C.h"
  2. include "mbed.h"
  3. include "SDFileSystem.h"
ADXL345_I2C accelerometer(D14,D15); SDFileSystem sd(D11,D12,D13,PB_6, "sd"); MOSI, MISO, SCLK, SSEL DigitalOut myled(LED1);
Serial pc(USBTX, USBRX);
int main() { pc.baud(115200); printf("RTC example\n"); set_time(1387188323); Set RTC time to 16 December 2013 10:05:23 UTC printf("Date and time are set.\n"); int readings[3] = {0, 0, 0};
pc.printf("Starting ADXL345 test...\n"); wait(.001); pc.printf("Device ID is: 0x%02x\n", accelerometer.getDeviceID()); wait(.001);
These are here to test whether any of the initialization fails. It will print the failure if (accelerometer.setPowerControl(0x00)){ pc.printf("didn't intitialize power control\n"); return 0; } Full resolution, +/-16g, 4mg/LSB. wait(.001);
if(accelerometer.setDataFormatControl(0x0B)){ pc.printf("didn't set data format\n"); return 0; } wait(.001);
3.2kHz data rate. if(accelerometer.setDataRate(ADXL345_3200HZ)){ pc.printf("didn't set data rate\n"); return 0; } wait(.001);
Measurement mode.
if(accelerometer.setPowerControl(MeasurementMode)) { pc.printf("didn't set the power control to measurement\n"); return 0; }
while (1) {
accelerometer.getOutput(readings); time_t seconds = time(NULL);
printf("/r/n/nTime as seconds since January 1, 1970 = %d", seconds);
printf("/r/nTime as a basic string = %s", ctime(&seconds));
char buffer[32]; strftime(buffer, 32, "%I:%M:%S %p", localtime(&seconds)); printf(" Time = %s", buffer);
myled = !myled; pc.printf("\r\n%i, %i, %i", (int16_t)readings[0], (int16_t)readings[1], (int16_t)readings[2]);
FILE *fp = fopen("/sd/PCE datalog.txt", "a");
fprintf(fp,"\r\n Accelerometer: X: %ig, Y: %ig, Z: %ig", (int16_t)readings[0], (int16_t)readings[1], (int16_t)readings[2]); fprintf(fp," Time = %s", buffer);
fclose(fp); wait(1);
wait(0.001); }
Can you find the mistake. thank you.
posted by Mohan gandhi Vinnakota 18 Aug 2015
A seperate forum topic/question would be handier. Then also use <<code>> and <</code>> around your code to make it readable. Finally give as much information as possible. Does it work if you just print to terminal? Does your SD card work if you just store a fixed string on it and nothing else?
posted by Erik - 18 Aug 2015
I could print sensor values to SD card. I could see sensor values with time stamp on serial terminal ( tera term). But i could not print sensor values with time stamp on SD card
#include "ADXL345_I2C.h"
#include "SDFileSystem.h"
 SDFileSystem sd(D11,D12,D13,PB_6, "sd"); // MOSI, MISO, SCLK, SSEL
       pc.baud(115200);
       set_time(1387188323); // Set RTC time to 16 December 2013 10:05:23 UTC
     wait(.001);
    wait(.001);
     // These are here to test whether any of the initialization fails. It will print the failure
         return 0;  }
     //Full resolution, +/-16g, 4mg/LSB.
     wait(.001);
        return 0;  }
     wait(.001);
     //3.2kHz data rate.
        return 0;    }
     wait(.001);
     //Measurement mode.
        return 0;   }
     while (1) {
       //printf("/r/n/nTime as seconds since January 1, 1970 = %d", seconds);
       // printf("/r/nTime as a basic string = %s", ctime(&seconds));
       char buffer[32];
       myled = !myled;
    fclose(fp);
        //wait(1);
        wait(0.001);
