11 years, 1 month ago.
I'm trying to make a uart communication with nucleo f401re
Hello, I just started using nucleo f401re and mbed.
I'm trying to build a system to control servo motor which uses uart system.
Before making the final design i'm experimenting with Serial library to implement design but keeps failing.
Here's the code I made,
Serial Practice
DigitalOut myled(LED1);
Serial motor(USBTX, USBRX);
char* start = "10139444";
motor.format(8, Serial::None, 1);
motor.baud(115200);
myled = 1;
motor.printf(start);
wait(1);
myled = 0;
wait(1);
My question is, if i change the pins of motor led doesn't turn on. For example if I change the satement
Serial motor(USBTX, USBRX); to Serial motor(D1, D0); the code doesn't seem to run.
What't the reason for my failure?
Thanks in advance.
By default, Arduino header pins D0 & D1 are disconnected on all Nucleos. Instead, Serial2 Tx/Rx are routed to the ST-Link board to give debug output over USB to host PC.
Refer to http://developer.mbed.org/platforms/ST-Nucleo-F401RE/ and choose other pins for your motor connection.eg Serial1 Tx/Rx on D8/D2.
Full schematics of the Nucleos are in http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00105823.pdf
