11 years, 2 months ago.
Thread interleaving question
Hi, I'm working on some threaded code. One thread processes input/output, while the main thread executes long_add, a dummy function. Code here:
main.cpp
#include "MODSERIAL.h"
#include "rtos.h"
DigitalOut led1(LED1);
DigitalOut led2(LED2);
MODSERIAL In(p13, p14); // serial object to read data coming in
MODSERIAL Out(p9, p10); // serial object to send data
MODSERIAL pc(USBTX, USBRX);
Timer in_timer;
Timer out_timer;
Timer print_timer;
int dataIn[32];
int dataOut[32];
osThreadId mainThreadID;
void io_thread(void const *args) {
for(int ii=0; ii<32; ii++) {
// pc.printf("ii is %d\r\n", ii);
Out.putc(ii);
int jj = 0;
while (In.readable() && jj < 32) {
//pc.printf("jj is %d\r\n", jj);
dataIn[jj]=In.getc();
jj++;
pc.printf("Time in io_thread: %f \r\n", (float)out_timer.read_us());
osSignalSet(mainThreadID, 0x1);
void long_add() {
int i = 0;
while ( i < 10000) {
int j = 0;
while (j < 100) {
j += 1;
i += 1;
mainThreadID = osThreadGetId();
// pc.baud(9600);
In.baud(921600);
Out.baud(921600);
pc.baud(921600);
in_timer.start();
long_add();
pc.printf("In time: %f \r\n", (float)in_timer.read_us());
out_timer.start();
Thread thread(out_thread);
long_add();
osSignalWait(0x1, osWaitForever);
// float temp2=out_timer.read_us();
//pc.printf("In time: %f \r\n", (float)out_timer.read_us());
By itself, the I/O thread function takes 450 us and long_add takes 417 us. However, with threading long_add takes only 420 us, while the I/O function takes an additional 600 us to run; I expected long_add would finish around 900 due to the interleaving, but it seems as if there's barely any interleaving happening. Is this a thread scheduling quirk, or is there something wrong with our implementation?
