11 years, 2 months ago.
doesn't work
led doesn't blink when i pressed button. i tried other "button" example but button doesn't work again. Do you thing my button is broken ? I just got my nucleo yesterday
11 years ago.
i am also having the same problem. I tired the interrupt based example also. That also does not work. I tried button interrupt using stm32 hal libraries, even after that it does not work.
10 years, 7 months ago.
Translating Dmitri's response: "Right-click on the mbed 'gears' [in the workspace panel], and on the pull-down menu click "update", and after re-compiling the application everything will work."
11 years ago.
Right button on mbed, and update... Правой кнопкой на шестерёнке mbed, и в ниспадающем меню нажать "update", после компилируйте приложение. Всё будет работать.
Hi Gökay, are you able to compile the program?
posted by Phillip B. 04 Feb 2015Hi Gokay, I have the same board and it works perfectly for me.
posted by Mark Greenaway 13 Mar 2015
