11 years, 3 months ago.
PN532 library for KL25Z or K20D50M
Hi, i'm trying to make work a Freedom Board (KL25z or K20D50M) with the NFC Shield from Seeedstudio. How do you change the library to work with these platforms?
thanks.
11 years, 2 months ago.
Split the application from the library. And try to define your own application then for your target, include that library and compile. If its generically implemented ,should work out fo the box (aka using mbed API)
