11 years, 2 months ago.
How yo power supply kl46z
i need to power suply with external source...a 8v battery pack via VIN pin. if i meassure output regulator i have 3.3v.. but the board doesnt start up...somebody what im doing wrong? what need to do? Thnks
I believe if you only power the Vin pin the OpenSDA interface part does not start up (which is used for programming). This means an LED is not enabled, but it should still run. Did you try it with just a blinky program?
