11 years, 3 months ago.
byte value instead of ascii in char array
First, I am new to the C language. I cobbled some example code to send some CAN data through the Ethernet port using UDP. Using sprint to fill the buffer, everything works and I send ASCII formatted data. I don't want ASCII though, I want actual byte values sent. So I tried to modify, and cant seem to figure it out.
This seems to work, but sends ASCII data:
sprintf(UDPdata, "%X,%X,%X,%X,%X,%X,%X,%X,%X",can_MsgRx.id,can_MsgRx.data[0],can_MsgRx.data[1],can_MsgRx.data[2],can_MsgRx.data[3],can_MsgRx.data[4],can_MsgRx.data[5],can_MsgRx.data[6],can_MsgRx.data[7]);
display.printf("%d",strlen(UDPdata)); //Shows 24 or so bytes, depending on data
udp.sendto( UDPdata, strlen(UDPdata), &multicast );
Tried this instead to send byte values, but the char array UDPdata appears to be empty before sending:
UDPdata[0] = (can_MsgRx.id & 0xff000000) >> 24; //can_MsgRx.id is an 32 bit unsigned integer, so mask and shift bits to break it in to 4 bytes
UDPdata[1] = (can_MsgRx.id & 0x00ff0000) >> 16;
UDPdata[2] = (can_MsgRx.id & 0x0000ff00) >> 8;
UDPdata[3] = (can_MsgRx.id & 0x000000ff);
for(i=0; i < can_MsgRx.len; i++) { //can_MsgRx.len is the length of the data message (always 8 bytes in this case)
     UDPdata[4+i] = can_MsgRx.data[i];//can_MsgRx.data is the actual data, a group of 8 bytes
display.printf("%d",strlen(UDPdata)); //Always shows 0
The display shows that the length of UDPdata is 0 in the second snippet. In addition, a packet capture shows that the packet is being sent, but it is empty.
Any ideas on how to fill the array with individual byte values and not a string?
Thanks
Sonny
Use putc commands to send bytes with out modification. You also can not get a printf to send 0x00. I use this for UART and SPI interfaces with complete success.
posted by John Johnston 12 Jan 2015
strlen() determines the length of the string by locating the position of the terminating null character. In this snippet, the compiler will add a terminating 0x00 to the ascii characters:
char * mystring="Hello World";
You can test the value of mystring[11], it will be zero.
You are misusing string functions on arrays of arbitrary non-ascii values; the value at UDPdata[0] (or somewhere else) may be zero in the context of your usage, so using strlen() to determine the total length will produce incorrect results.
Instead, use (4+can_MsgRx.len) as the number of bytes to send.
That was it for sure. The first byte is almost always 0x00, so it was never sending any data. Modified to send 4+data bytes and it works perfectly.
Thanks
posted by Sonny Ovens 11 Jan 2015
Use putc to send binary bytes. I use this for UART and SPI interfaces.
