10 years, 8 months ago.
How to enable duplex SPI communication with two F401RE boards?
Hi
Could you please help me to setup a duplex communication i.e. How can I read data sent by slave SPI board? So far, I have been able to send data from master to slave and the code is as follows:
Thanks a lot
//======================== SPI Master====================================
Serial pc(USBTX, USBRX);
SPI deviceMaster (PB_5, PB_4, PB_3);// mosi, miso, sclk
DigitalOut cs(PA_9);
    pc.printf("Communicating with PC...\n");
    cs = 1; // Chip must be deselected
    deviceMaster.format(8,2);
    deviceMaster.frequency(1000000);
    int values[5] = {0, 5, -15, 10, 55};
    int i = 0;
    int val = 0;
        if (i < 4){
            i++;
            else
                i = 0;
        val = values[i];
        cs = 0; // Select the device by seting chip select low
        deviceMaster.write(val);
        cs = 1;
        //int value = deviceMaster.read();
            pc.printf("Master Transmission...\n");
            pc.printf("%d  \r\n", val);
            wait_us(1000000);
//======================== SPI Slave ====================================
// Reply to a SPI master as slave
 #include <SPISlave.h>
SPISlave device(PB_5, PB_4, PB_3, PA_4); // mosi, miso, sclk, ssel
     int v = 0;
     device.format(8,2);
    device.frequency(1000000);
     device.reply(0x00);              // Prime SPI with first reply
         if(device.receive() == 1) {
             v = device.read();   // Read byte from master
             //device.reply(v);         // Make this the next reply
            pc.printf("Slave Transmission...\n");
            pc.printf("%d  \r\n", v);
10 years ago.
The SPI Master is always in control of the communication with the Slave. A Slave can never send data on its own initiative. It will send its data while it receives a byte from the Master. Try this code
//Master
char slavedata;
cs = 0; // Select the device by setting chip select low
slavedata = deviceMaster.write(val);  // Master is sending and receiving at the same time
cs = 1;
pc.printf("Master Received..%d\r\n", slavedata);
     device.reply(0x00);              // Prime SPI with first reply, this data will be send to the Master
     if (device.receive() == 1)  {  // check to see if anything was received from the Master
        pc.printf("Slave Received..%d\r\n", v);
