11 years, 2 months ago.
Default IO Settings
How do I find out the default IO register settings used for this Platform? (nRF51822-mkit)
Example: What are the settings or timing used by nRF51822-mkit with the mbed AnalogIn declaration?
How do I change those settings, or where in the code should I put register writes if I need slightly different settings?
here are sources : https://github.com/mbedmicro/mbed/tree/master/libraries/mbed/targets/hal/TARGET_NORDIC/TARGET_MCU_NRF51822. There are also available here on mbed as (mbed-src), but currnetly are not updated due to an error.
Look at HAL implementation and you should find there everything you asked above.
0xc0170
