11 years, 2 months ago.
Way of downloading firmware and debugging of Seeed Arch Max with Keil MDK 4.0
Are there way of downloading firmware and debugging of Arch Max same as Nucleo? I usually download firmware and debug with Keil MDK 4 using STLink. Can I do the same thing with Arch Max? Do I need to have STLink adapter and cable?
The Arch Max is an mbed enabled development board for rapid prototyping. It's based on a STM32F407VET6 microcontrolle with an ARM Cortex-M4F core running at 168MHz. It includes an open …
Using Arch Max with Keil MDK is almost the same. Just choose "CMSIS DAP debugger" instead of "STLink debuger" in the options dialog (options -> debug and utilities).
Yihui
Thank you. I'll try it.
posted by Hill Kim 06 Jan 2015
Maybe good to mention that you need to install the driver (mbedWinSerial_16466.exe) to have the CMSIS DAP debugger link.
posted by Gunter Otté 06 Mar 2015
