11 years, 2 months ago.
EA LPC4088 interrupt input
using the interruptin example, generates an error and does not work board
I got following runtime error using InterruptIn example:
pins on this port cannot generate interrupts
The reason of this is the device only supports GPIO0 and GPIO2 for GPIO interrupt. In gpio_irq_init() function of gpio_irq_api.c, it checks available port for interrupt input.
int gpio_irq_init(gpio_irq_t *obj, PinName pin, gpio_irq_handler handler, uint32_t id) {
if (pin == NC) return -1;
irq_handler = handler;
obj->port = ((int)(LPC_GPIO0_BASE+pin) & ~0x1F);
obj->pin = (int)pin % 32;
// Interrupts available only on GPIO0 and GPIO2
if (obj->port != LPC_GPIO0_BASE && obj->port != LPC_GPIO2_BASE) {
error("pins on this port cannot generate interrupts");
Pinname 'p5' is defined as P1_24 in target specific PinNames.h.
Therefore, you can not use 'p5' pin for InterrutIn API using the EA LPC4088 target.
