11 years, 4 months ago.
Can't load drivers - 'The driver could not be installed. No mbed Microcontrollers were found'.
Cannot install windows serial drivers for ARCH GPRS V2 (SEEEDSTUDIO) board!7
I read the same message: "No mbed Microcontrollers were found" and stops here...
Usb cable is ok, i have just checked it.
Please can you suggest an hint for this problem. Thank you,
That isn't the right driver for the device. That driver is for mbed platforms with an programming and debug interface MCU. The ARCH GPRS lacks this onboard circuit.
Have a look at the getting started section here. http://www.seeedstudio.com/wiki/Arch_GPRS_V2
I don't see any mention of a driver.
I'm having the same problem. Trying to install version 16466. The mbed compiler 'sees' and loads to my STM32F411RE Nucleo board just fine. Win7, 64-bit.
posted by Duane Brantley 25 Dec 2014
