11 years, 3 months ago.  This question has been closed. Reason: Duplicate question
Help with classes
I'm trying to create a class that contains a private CAN bus. I've going through the cook book "Writing a library" and I figured out how to cover most of my class but I'm stumped on getting the CAN correctly.
Car.h
#ifndef MBED_CAR_H
#define MBED_CAR_H
class Car
public:
    Car();
    double _test;
private:
    CAN _canBus;
#endif
and then
Car.cpp
#include "Car.h"
Car::Car()
    _test = 10;
    CAN _canBus(p30, p29);
    _canBus.frequency(250000);
void Car::CanRcv()
    DigitalOut led1(LED1);
    CANMessage msg;
    if(_canBus.read(msg)) {
        led1 = !led1;
I'm certain that isn't the correct way to go about it, and I've tried to do it in a similar fashion to the tutorial before, but I can't quite get it.
The code above isn't really something I expected to work, more just a representation of what I want to happen. Where _canBus is a private member, and is then initialized in the constructor. It does not have to occur exactly like this, my intention is only to have the CAN bus initialized as a part of the class.
Random example on how to do it (but then DigitalOuts): http://developer.mbed.org/users/simon/code/TextLCD/file/308d188a2d3a/TextLCD.cpp
In other words, in your .cpp file you need to add at line 4 :_canBus(p30, p29), then remove line 8.
