11 years ago.
Always comes up as BOOTLOADER after upgrade
I followed the Firmware upgrade instructions, but now when I plug the board in, it ALWAYS is 'seen' as BOOTLOADER and NOT MBED. What happened? What do I do now??
Thanks, Duane
10 years, 8 months ago.
Hi Guys, Did you ever get this resolved? If so what did you do. If not @Duane - looking at the html it seem to indicate that the bootloader might not be the latest version
You might try to upgrade it as described here
https://developer.mbed.org/handbook/Firmware-FRDM-K22F
here's the direct link https://developer.mbed.org/media/uploads/sam_grove/0221_k20dx128_k22f_0x8000.bin
Please let us know how you get on., Regards Ivan Vernot realtimedesigns.com.au
11 years ago.
hi,
there was the same question a days ago asked. Do you have any instrument to measure reset line for the interface chip? I suspect it might be still active (low) when the interface is checking it...
Although I checked the bootloader, and I havent seen any changes there regarding my assumption above.
0xc0170
11 years ago.
Hi I have the same issue but discovered that if you put the compiled target code on the device then restart it works fine. Regards Phil
Sounds like what I did. When I initially plugged the FRDM board in, it 'came up' as mbed. Per instructions, I unplugged the board, held the 'reset button' down and plugged the board back in. It came up as BOOTLOADER, per instructions. I copied the upgrade firmware to BOOTLOADER USB drive, verified it was there, then unplugged the USB/power, waited a few seconds and plugged the USB back in. But instead of coming up as a drive named mbed, it came up as the same BOOTLOADER drive, and the compiler doesn't recognize it. Basically, useless now. . .
Duane
posted by 16 Dec 2014That's what mine does, but if you actually put a compiled program on it, it actually runs it, even though the device appears as the Bootloader drive.
posted by 16 Dec 2014Hi Sam,
Here is the contents of the htm:
<! mbed Microcontroller Website and Authentication Shortcut >
<! Version: 1000 Build: Jun 13 2014 10:16:46 >
<html>
<head>
<meta http-equiv="refresh" content="0; url=http://mbed.org/device/?code=ffff10001E131E4E0E13E1B1"/>
<title>mbed Website Shortcut</title>
</head>
<body></body>
</html>
Hope this helps to point to the problem.
Duane
posted by 17 Dec 2014
