11 years, 3 months ago.
DS1820 get address
Maybe someone can sugest how to read ROM address from DS1820
Thank you
11 years, 2 months ago.
Read ROM [33h] This command can only be used when there is one slave on the bus. It allows the bus master to read the slave’s 64-bit ROM code without using the Search ROM procedure. If this command is used when there is more than one slave present on the bus, a data collision will occur when all the slaves attempt to respond at the same time.............
Look here http://www.hacktronics.com/Tutorials/arduino-1-wire-tutorial.html It should help.......
posted by Quincy Magoo 29 Jan 2015
